Introduzione
This guide was labeled “Obsolete” on 2/14/2022. This was done as this procedure only applies to older iPods and iPhones which are beginning to age, with a good chunk of older iPhones (primarily 5s and older, with some blocking the 6 and allowing the 6s) being activation blocked due to the 3G shutdowns, and Sprint network shutdown affecting most older Sprint specific iPhones. This will still work for older devices, but this guide will no longer be updated. I am leaving this guide up for the foreseeable future.
Guide notes
- (iPhone only) This method only works up to the iPhone 6s. The current method varies by device on newer models.
- iCloud warning: Devices running iOS 7 or newer will have an iCloud activation lock. If you restore a device with unknown credentials, you will no longer be able to use the device. Furthermore, devices with an unofficial iCloud unlock will no longer work.
- With iOS 8 and up, the device data is encrypted. If you need your data, you must guess the password.
- WARNING: ALL DATA ON THE DEVICE WILL BE ERASED! IF POSSIBLE, GUESS THE PASSWORD.
If you purchased a used iDevice or forgot the password on your current device, this guide will show you how to restore the device so you can use it again. If you did not forget the password but are having problems that prevent a normal recovery, this method can also be used for this purpose.
Plug your device into your computer. Use the correct cable for your device.
Once the device is plugged in, verify it shows up in iTunes. The device will not sync while it is locked, but this is expected.
Reset the device. Hold both the power and home buttons down at the same time. Do this until the device screen turns black.
This is the power button.
This is the home button.
Once the Apple logo shows up on the screen, let go of the power button. Hold the home button until the recovery mode screen comes up.
If you have done the previous steps correctly, the device will show in iTunes, but prompt it is in recovery mode.
Click Restore iPod/iPhone/iPad and then Restore and Update. Agree to the EULA.
Once you agree to the EULA (not shown), iTunes will download the latest firmware. Your device will be restored once this is finished.
Once the device is restored, set it up as a new device. Make a new backup to use moving forward.
Altre 35 persone hanno completato questa guida.
10 Commenti
So what happens when this dosen't work?
you are a life saver!!!! thank you so much!
This worked. You must continue to hold the home and power button until the apple logo shows up. Once it shows up, hold the home key. Your iTunes will then have a couple prompts.
A couple days ago, I bought myself a used iPhone 3G for $25. It didn’t have a SIM card, but I was able to connect it to my MacBook Pro, fire up iTunes, and basically load the same songs that are on my iPod on it. I was even able to download and install an app I had downloaded from the programmer’s website a few years ago I was sure hadn’t been updated.
All good so far … until I decided to add a password, and then decided that maybe updating the phone’s OS might be a good idea. The password was the same as that of my iPod … but after the update, suddenly I “typed in the wrong pass code.”
After fighting with that for a few hours, I did the restore bit … but now, since there is no SIM card (did I mention I have three phones? No need for another), I can’t get back to where I was before the stupid software update and now I have a phone I can’t use for the purpose for which I bought it.
Thanks, Apple.
That said, any ideas on how to get past that SIM card issue?
Okay, so I got on eBay and bought a SIM card “for testing purposes” for about three bucks. It may or may not work, but it should at least get me past the “Dude. You Need a SIM Card” error.
We’ll see how that goes.
Good news! Got a SIM card. Bad news: It was too small to fit into the holder in the phone.
After a quick trip to my local T-Mobile store, I had an adapter — which, I just discovered, I probably could have made myself, according to this article:
Crea un adattatore da microSIM a SIM
Alas, the SIM card I stuck in there was identified as not being one of the phone’s supported carriers … so we’ll see.
I have a 8+ n it has a activation lock don’t it since I was scammed so help me so I can use it or sell it
Apparently I left my second gen iPod Touch on, face down on coffee table, and untouched … for about six months. Today I wanted to check something on it, and when it didn’t power up, I connected it to my MacBook Pro.
Everything seemed to be fine, except I couldn’t set the date or time. Each time I had the time almost correct, the wheel would turn, leaving me with (once again) a date from 1969.
Couldn’t connect to the App Store, because of the system’s date. Google wasn’t much help, so after trying a few things that didn’t work, I came here and sure enough, I’m not the only person that had that problem!
Kudos to the author of that guide!
This worked like a charm. Thanks.
At this point it's coming in my computer: itune couldn’t connect to iPod because it's locked with a passcode.
any idea how to solve that?
Mer - Replica
That’s normal. Put the device in recovery mode and it will not have that problem. Just bear in mind you won’t be able to do a backup of your data.
Nick -
