Salta al contenuto principale
OBSOLETE - How to Remove a stuck game from an Xbox 360
Cosa ti serve
  1. OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: passo 1, immagine 1 di 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: passo 1, immagine 2 di 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: passo 1, immagine 3 di 3
    • Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
  2. OBSOLETE - How to Remove a stuck game from an Xbox 360, Find the emergency eject hole: passo 2, immagine 1 di 1
    • With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
    • The system in the guide does not have this hole. In this example, opening the console is likely the only way to get your game out if the optical drive does not respond.
  3. OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: passo 3, immagine 1 di 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: passo 3, immagine 2 di 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: passo 3, immagine 3 di 3
    • Reinstall the faceplate on the system. To do this, put even pressure on all parts of the faceplate until it is completely flush with the console.
    • If you are in doubt, it may not hurt to run your hand over the faceplate to make sure and do a visual inspection.
Conclusione
Altre 19 persone hanno completato questa guida.
Nick
Membro da: 11/10/09
88.752 Reputazione
49 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.521 Guide realizzate
2 Commenti
will this work for elite 250 gug
duangphetv - Replica
I have my xbox here but in the pictures I think I have a upgraded xbox 360 and it does not have some of the buttons it had on the pictures but I can't find a place to un clip the face of it
Maddy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 31,404
