Introduzione
本指南提供了如何卸下硬盘的详细步骤,硬盘是允许用户自行更换的。
  1. 首先断开设备电源并将电源线拔出。向左滑动硬盘盖(顶部左侧部分)。
    • 首先断开设备电源并将电源线拔出。向左滑动硬盘盖(顶部左侧部分)。
  2. 在PS4的左前方卸下一颗5mm Phillips head #1螺丝后可以卸下硬盘。
    • 在PS4的左前方卸下一颗5mm Phillips head #1螺丝后可以卸下硬盘。
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. 向前滑动硬盘以将其卸下。
    • 向前滑动硬盘以将其卸下。
  5. 在硬盘盒侧面卸下四颗螺丝。如图在另一侧有两颗相同的螺丝。
    • 在硬盘盒侧面卸下四颗螺丝。如图在另一侧有两颗相同的螺丝。
  6. 从架子上卸下硬盘。
    • 从架子上卸下硬盘。
Conclusione
参考以下步骤的相反顺序以重新组装你的设备。
Altre 141 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Z.Heng ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Robert Harvey
Membro da: 01/04/2014
7.481 Reputazione
5 Guide realizzate
Cal Poly, Team 8-12, Regan Spring 2014 Membro di Cal Poly, Team 8-12, Regan Spring 2014
CPSU-REGAN-S14S8G12
5 Membri
32 Guide realizzate
This article needs to be vetted. There is a very specific type of hard drive needed for this machine. Also, the machine will need to be backed up to either the PS Network(for PS Plus members) or a removable storage device. Additionally, the latest system update must be available after the new hard drive is installed. Below is an excellent article for this procedure.
http://www.ign.com/wikis/playstation-4/H...
Kenneth Stockman - Replica
can I take out my 500 gig and put in a 1 tb or no ?
Phil manwarren - Replica
Hey Phil,
Yes, you can. I have successfully replaced the original hard drive with a 2TB hard drive I purchased. Just make sure you buy the correct type of hard drive. I recommend using the article Kenneth has linked above in the comment section: http://www.ign.com/wikis/playstation-4/H...
I backed up my saved data on the PS network instead of using an external hard drive and that worked great.
Enjoy the extra storage!
Joel Praino -
Yes you can upgrade to 1TB or even bigger. Last PS4 firmware update was in august, and it supports storage up to 4TB. You can also use bigger storage but it may result in error.
You can update 2.4-internal HDD or use something like Nyko data bank to use 3.5 inch drives. Also external hard drives is an option, but in order to use them you will need to install the software and games on it.
ps4 hard drives:
http://hddmag.com/2016/07/top-7-best-ps4...
http://www.ryli.net/ps4-hard-drive-guide...
janis kalnins - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 176
Ultimi 30 Giorni: 879
Tutti i Tempi: 50,476
