Cosa ti serve
Panoramica Video
首先卸下后盖。很遗憾我们这次展示如何更换相机镜头玻璃盖的S6后盖破损了。
首先用热风枪或iOpener加热手机后盖,然后将吸盘压在后盖靠下的位置,向上拉起一些露出空隙后插入一个塑料撬片。
沿着手机边缘滑动塑料撬片以松开粘合剂,插入另外的塑料撬片支撑边角,重复步骤松开所有的粘合剂。
请按逆序重装你的设备。
请按逆序重装你的设备。
Altre 54 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
27 Commenti
Is it possible to replace just the lens without taking off the back cover? Like can I just use a suction tool to pull off the broken lens and put in the new one?
Yes, that is possible!
Robin -
Yes. It can be done. I did it using a hair dryer to warm the lens and peel if off gently, starting in one corner. If it seems reluctant to come off you may need to heat it a little more. Be careful not to damage to outer metal ring (as I did) and then replace the glass lens as described.
