Salta al contenuto principale
iBook G4 12" 800 MHz-1.2 GHz RAM Replacement
Cosa ti serve
  1. iBook G4 12" 800 MHz-1.2 GHz RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 12" 800 MHz-1.2 GHz RAM Replacement: passo 2, immagine 1 di 1
    • Lift the battery out of the computer.
  3. iBook G4 12" 800 MHz-1.2 GHz RAM Replacement, Keyboard: passo 3, immagine 1 di 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  4. iBook G4 12" 800 MHz-1.2 GHz RAM Replacement: passo 4, immagine 1 di 1
    • If the computer has an AirPort card installed, follow the next three steps to remove it.
    • Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
  5. iBook G4 12" 800 MHz-1.2 GHz RAM Replacement: passo 5, immagine 1 di 1
    • Grasp the clear plastic tab on the AirPort card and pull toward the display.
  6. iBook G4 12" 800 MHz-1.2 GHz RAM Replacement: passo 6, immagine 1 di 1
    • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
  7. iBook G4 12" 800 MHz-1.2 GHz RAM Replacement: passo 7, immagine 1 di 1
    • Remove the four silver Phillips screws that secure the RAM shield.
  8. iBook G4 12" 800 MHz-1.2 GHz RAM Replacement: passo 8, immagine 1 di 1
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
  9. iBook G4 12" 800 MHz-1.2 GHz RAM Replacement: passo 9, immagine 1 di 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
  10. iBook G4 12" 800 MHz-1.2 GHz RAM Replacement, RAM: passo 10, immagine 1 di 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  11. iBook G4 12" 800 MHz-1.2 GHz RAM Replacement: passo 11, immagine 1 di 1
    • Pull the chip directly out from its connectors.
Conclusione
Altre 38 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 60,008
