Hard Drive
7 Risposte Punteggio 17 |
I can't add files to my Seagate FreeAgent external hard drive. |
3 Risposte Punteggio 3 |
Error: The file or directory is corrupted and unreadable |
1 Risposta Punteggio 0 |
My external drive is creating clicking sounds PLS HELP |
Indicator light doesn't turn on, pc doesn't recognise it, hear it spin |
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Background and Identification
The Seagate FreeAgent Go is a portable external drive for photos, music, videos, and more by Seagate. FreeAgent external hard drives range in size from 60 GB to 3 TB. The FreeAgent Go was released in May 2010 as an updated range of FreeAgent drives including the FreeAgent Desk, FreeAgent GoFlex, and FreeAgent Xtreme. The FreeAgent Go is a 2.5-inch drive with a maximum internal storage of 1 TB. The Go Special Edition includes the same specifications as the original Go drive but includes a different case. All FreeAgent drives support USB 2.0.
Mac-compatible versions of the FreeAgent storage drives have different designs and support FireWire 800, 400, and USB 2.0. Although the drives are supplied with different software and styling, any FreeAgent drive can be used as a storage device on any computer with the appropriate port if an appropriate file system is installed on the drive and supported by the computer.
The Seagate FreeAgent Go can include an accessory pack that comes with a docking station and a travel case. Users can plug their drive into the FreeAgent dock to access their files without any cables. The Seagate FreeAgent Go was released with storage capacities of 250 GB, 320 GB, and 500 GB. Users can automatically back up their data, synchronize files, and encrypt important files and folders.
Technical Specifications
Model Numbers:
- 250 GB Silver:
** Model Number: ST902503FGA2E1-RK
- UPC: 763649008034
- Multi-Pack UPC: 10763649008031
- 250 GB Black:
- Model Number: ST902503FAA2E1-RK
- UPC: 763649011652
- Multi-Pack UPC: 10763649011659
- 320 GB Silver:
** Model Number: ST903203FGA2E1-RK
- UPC: 763649008102
- Multi-pack UPC: 10763649008109
- 320 GB Black:
- Model Number: ST903203FAA2E1-RK
- UPC: 763649011683
- Multi-pack UPC: 10763649011680
- 320 GB Blue:
** Model Number: ST903203FBA2E1-RK
- UPC: 763649011843
- Multi-pack UPC: 10763649011840
- 320 GB Red:
- Model Number: ST903203FDA2E1-RK
- UPC: 763649012093
- Multi-pack UPC: 10763649012090
- 500 GB Silver:
- Model Number: ST905003FGA2E1-RK
- UPC: 763649008171
- Multi-pack UPC: 10763649008178
- 500 GB Black:
** Model Number: ST905003FAA2E1-RK
- UPC: 763649011751
- Multi-pack UPC: 10763649011758
- Dock / Case Silver / Black:
- Model Number: 100521233
- UPC: 763649011935
- Multi-pack UPC: 10763649011932
PC Requirements
* Windows Vista Home Basic, Home Premium, Ultimate, or Business Service Pack-1
- Windows XP Home, Professional, Media Center Edition Service Pack-2
- USB 2.0 Port
Performance Specs
- USB 2.0: up to 480 Mb/s
- Rotational Speed: 5400 RPM
Product Retail Packaging Specs
- Box dimensions: 7.00 in H x 2.00 in W x 5.75 in L (177.8 mm x 50.8 mm x 146.1 mm)
- Box weight: 9.60 oz (0.27 kg)
- Master carton dimensions: 7.63 in H x 9.68 in W x 11.68 in L (196.7 mm 245.9 mm x 296.6 mm)
- Master carton weight: 3.52 lb (1.62 kg)
- Master carton quanti ty: 4
- Master cartons per pallet: 80
- Pallet dimensions: 43.13 in H x 40.00 in W x 48.00 in L (1,095.5 mm x 1,016.0 mm x 1,219.2 mm)
- Pallet weight: 334
