1 Diagramma
Domande popolari nel forum
Fai una domandaNon ci sono domande. Puoi essere il primo a porre una domanda!
Documenti
Modelli
GA7021
Background
The Makita GA7021 is a durable angle grinder equipped with a 7-inch grinding wheel and a 15-amp motor, offering substantial output in a compact design. The grinder's labyrinth construction contributes to a longer tool life by safeguarding the motor and bearings from dust and debris. Furthermore, the GA7021 includes a side handle installable on either side of the tool for user convenience. The model number is located on the nameplate on the side of the grinder.
Technical Specifications
- Dimensions: 19.5 x 8.5 x 6.5 inches
- Weight: 12.6 lbs
- Wheel Diameter: 7 inches
- Motor: 15-amp
- No Load Speed: 6,000 RPM
- Spindle Thread: 5/8-inch-11 UNC
- Switch Type: Rear trigger switch
- Cord Length: 8.2 feet
