1 Diagramma
Domande popolari nel forum
Fai una domandaNon ci sono domande. Puoi essere il primo a porre una domanda!
Modelli
9557PBX2
Background
The Makita 9557PB is a die grinder, a tool used for grinding, sanding, honing, polishing, or machining material. The primary component of this tool is its 7.5 amp motor which is capable of delivering a no-load speed of 11,000 RPM. It comes with a 4-1/2" grinding wheel that can be easily changed thanks to its spindle lock feature. The tool's design includes a paddle switch for operation, a feature that promotes convenience for the user. Additionally, it has a labyrinth construction, a design element intended to protect the motor and bearings from contamination, thus potentially increasing the lifespan of the tool.
In terms of usage, the Makita 9557PB is suitable for a variety of metalworking applications, such as grinding, cutting, and deburring. Its speed and power make it particularly useful for heavy stock removal and grinding of steel. This die grinder can be used with a wide range of abrasive wheels, cut-off wheels, and wire wheels, thus enhancing its versatility. Its design allows for operation in tight spaces, and the paddle switch provides control while enabling the user to maintain a two-handed grip on the barrel handle.
Technical Specifications
- Model Number: 9557PB
- Product: Makita Die Grinder 9557PB
- Product Type: Die Grinder
- Motor: 7.5 amp
- No Load Speed: 11,000 RPM
- Wheel Size: 4-1/2"
- Switch Type: Paddle switch for AC/DC operation
- Construction: Labyrinth construction seals motor and bearings from contamination
- Design: Barrel grip design for easy handling
- Additional Feature: Spindle lock for easy wheel changes
- Weight: 6.45 lbs
- Dimensions: 14" x 5" x 6"
- Accessories included: 4-1/2” grinding wheel, wrench, side handle, flange, wheel guard
Warranty
The Makita 9557PB 4-1/2" Paddle Switch Angle Grinder comes with a limited warranty that spans for a duration of one year. This warranty coverage provides assurance against any potential defects or issues that may arise due to the manufacturing process. In the event that you experience any problems with the product within this period, you are eligible to claim the warranty. To do this, you would typically need to contact Makita's customer service, providing them with details of the issue as well as proof of purchase. It is important to note that the warranty might not cover issues arising from misuse or damage caused by the user.
