8 Diagrammi
Domande popolari nel forum
Fai una domandaNon ci sono domande. Puoi essere il primo a porre una domanda!
Modelli
K4400G
Background
The Karcher K4400G is an electric pressure washer produced by Kärcher, a German company known for their cleaning systems and equipment. Launched in 2019, the K4400G is intended for home use and light commercial tasks.
The K4400G operates on a 1800 watt electric motor, producing up to 2200 PSI of water pressure and a flow rate of 1.3 gallons per minute. It is equipped with a hardened steel and brass axial cam pump, a 35-foot high-pressure hose, and a 20-foot power cord. The model includes a detergent tank that can be combined with the pressurized water, allowing the user to apply soap or other cleaning chemicals. It comes with a variable pressure wand, which includes a 25-degree and 40-degree nozzle. The model weighs 43 pounds and measures 19" x 12" x 33" (LWH). It also has 10" pneumatic tires for movement.
Technical Specifications
- Model Number: K4400G
- Product Type: Pressure Washer
- Electric Motor: 1800 watt
- Water pressure: Up to 2200 PSI
- Flow rate: 1.3 gallons per minute
- Pump type: Axial cam pump made of hardened steel and brass
- Hose length: 35 foot high pressure hose
- Power cord length: 20 foot
- Detergent tank: Yes
- Pressure wand: Variable pressure wand with a 25 degree and 40 degree nozzle
- Weight: 43 pounds
- Dimensions: 19" x 12" x 33" (LWH)
- Tires: 10" pneumatic tires
- Additional Features: Onboard hose and cord reels, water-cooled induction motor, garden hose inlet with adaptor, steel braided high pressure hose, pressure dial, onboard nozzle storage.
Warranty
The Karcher K4400G pressure washer comes with a 1-year limited warranty. This warranty is designed to cover any defects in the materials or workmanship of the product. However, it's important to note that the warranty is limited, which typically means it may not cover all parts or potential issues with the pressure washer. To claim the warranty, you should first ensure you have proof of purchase. Then, you will likely need to contact Karcher's customer service to report the issue and they will guide you through the necessary steps for warranty service. It's always a good idea to consult the product's user manual or the manufacturer's website for specific details and instructions on warranty claims.
