1 Diagramma
Domande popolari nel forum
Fai una domandaNon ci sono domande. Puoi essere il primo a porre una domanda!
Documenti
Modelli
315.10113
Background
The Craftsman Electric Drill, model number 315.101130, is a power tool manufactured by Diehl Mfg Co for Sears under the Craftsman Brand. The drill has been designed for various drilling purposes. It can be used for drilling holes in wooden or metal surfaces, as well as more rigid materials like masonry. By changing the bits, users can also bore larger holes using hole saws or wood boring bits. With its double insulation system, the drill isolates all exposed metal parts from the internal metal motor components, which eliminates the need for the usual three-wire grounded power cord. The drill is also designed to work with extension cords, which can be useful when working in larger areas.
The Craftsman Electric Drill operates on alternating current and is equipped with a 1/2 inch chuck. The tool's no load speed indicates its rotational speed when not under any load. The drill is constructed using class II construction, which means it is designed with double insulated construction tools. This feature eliminates the need for grounded power cords and power supply systems, making the tool safer to use. The drill is also designed to withstand the wear and tear of abrasive materials, making it a durable option for various drilling operations.
Technical Specifications
- Model Number: 315.101130
- Product Type: Electric Drill
- Chuck Capacity: 1/2 in.
- Input: 120 Volts, AC, 60 Hz
- Rating: 6.0 Amperes
- No Load Speed: 0-800 RPM
- Switch: Variable Speed/Reversible
Warranty
The Craftsman Electric Drill 315.101130 comes with a full one-year warranty. If the drill fails to provide complete satisfaction within one year from the date of purchase, you can return it to the nearest Sears store in the United States for free repair. However, please note that if the drill is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. It is important to save the warranty information and keep it safe. Sears, Roebuck and Co. is responsible for honoring this warranty and can be contacted at DepL 817WA, Hoffman Estates, IL 60179.
