Sound but no picture?
From what I am reading it is the power board that is bad. Can someone confirm this for me and it is something I can do myself?
This TV is only 2 years old.
Any help is appreciated.
Questa è una buona domanda?
I would think that this could be caused by a bad power supply or/and by bad y sustainer and z sustainer boards. Check the fuses on the y/b will give you a good idea where to start. If they are bad then you'll have a easy fix, if not, i would try replacing the y board first. Also check on your LED's and see if you get an error code. The service manual is available right here Good Luck and I hope that this will help you out.
thanks old turkey :)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,684
any error codes blinking on your LED's?
da oldturkey03
