Salta al contenuto principale
After 25 years from the introduction of the first-generation Range Rover, the second-generation Range Rover—model-designation P38A—was introduced for the 1995 model year, with an updated version of the Rover V8 engine.
2 Domande Visualizza tutte
Rear wobbly wheel, and rim and tyre A1
2001 Range Rover P38
Fast or slow speed, rear off side wheel wobbles ! Tyre place checked wheel and tyre, balanced it again to no avail. Refitted and still wobbles !
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@robinvanboxel check the wheel bearing as well as the hub. Check to make sure that your half shaft assembly is not worn out or bend or has a worn bearing. You also want to check all the bushings of your Panhard rod and radius arms.
This document may help you to get started on thisRange-Rover-P38-Rear-Suspension.pdf
Punteggio 2
Aggiungi la tua risposta
Rob sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 203
