Salta al contenuto principale
Is samsung galaxy s3 neo i9301 motherboard compatible with i9300 LCD
So my samsung galaxy s3 neo LCD display was damaged and so i want to replace my motherboard into another LCD display and frame.
I wanted to know if my neo's i9301 motherboard is compatible with a regular samsung galaxy s3 i9300 LCD display and frame. I have heard different things through research and wanted to know for sure before buying a LCD display+frame or just a LCD display.
I need to know this as the i9301 LCD displays and frames are considerably more expensive than a regular i9300.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
I took mine apart and the i9301 OLED (not LCD) is completely different.
Best case you might get a washed out grainy picture if the power lines are in the right place, worst case expensive smoke. The critical part is actually the display itself and some have a separate connector on the right hand side with about 18 wires on a 2 layer micro-ZIF connector.
The problem is that the higher resolution screens have more data bus lines (usually these are a variant of LVDS) and you can see this because each one has a ground plane either side of it.
On my S4 mini the bus has 6 "lanes" and on the S3 Neo 10.
You are better off getting the right screen and selling the old one on, if you are stuck PM me and I can sell you my i9301 (used, has minor damage but works) panel for a fair price.
Whats wrong with the old one if you don't mind me asking? as the parts on it can be recycled and for my purposes some OLED damage may be acceptable as long as some of the screen shows correctly.
Punteggio 0
From my experience, it kinda works, well the back plate of the S3 neo doesn't snap onto the S3 display, so that's one issue, but the image and touch appears to work fine
By the way I know this question is 8 years old but in case some retro enthusiast (like me) or your still looking to repair it, it works but back cover doesn't fit in
Punteggio 0
Aggiungi la tua risposta
Martin Howard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,419
