You are going to get through this...
See: https://www.macissues.com/2015/05/08/how...
(Chris Kessler who wrote this has been right on for me forever about the strangest issues)
''Unfortunately it appears that some systems may have troubles with hibernation mode, so if you are finding your Mac unable to wake from sleep, then are three potential fixes you can try:
Turn off system hibernation
Since hibernation mode’s only real benefit is to allow you to resume from sleep in the face of a power loss, a simple solution may be to turn hibernation mode off by running the following two commands in the OS X Terminal (enter your password when prompted–it will not show):
sudo pmset standby 0
sudo pmset autopoweroff 0
These commands will turn off the hardware settings that will put your Mac into hibernation mode. The first is Apple’s main standby mode option, and the second is an implementation required for European energy regulations. To reverse these commands, you can again either reset your Mac’s system management controller, or re-run the commands but use “1” as the value instead of “0.”
Disable and re-enable FileVault
The writing and restoring of memory contents from disk may conflict with FileVault or other full disk encryption routines. Technically when waking from hibernate mode the system should allow you to authenticate and then load the contents of the hibernation file, but if a bug prevents this from happening, then your Mac may not be able to load the hibernation file, and could hang.
To hopefully overcome this, first try disabling your full-disk encryption routines. After your disk is fully decrypted (this may take a while) test hibernate mode to see if it works properly, and then re-enable disk encryption and test again.
Remove your the system’s hibernation file
A final approach you can try is to remove the system’s hibernation file, which is the hidden file that is written to whenever your Mac goes into hibernation mode. While the system will recreate this file if it is missing, if present then it will just write to the existing file. As a result, any damage to this file may prevent the system from reading it when waking from sleep. To fix this, you can force OS X to recreate it by deleting it, which can be done by running the following command in the Terminal:
sudo rm /var/vm/sleepimage
Again supply your password when prompted, and then see if hibernate mode works properly.''
Sleep well again, 'handout'
JRP
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
6 Commenti
I have this exact problem, with this exact model (MacBook 5,1 - late 2008). I assume my logic board is fried but the timing is odd, since I left it unplugged so I don't see how that would have happened.
Do your battery status lights show it's fully charged too?
da Chris
Yes my battery status lights show they are now fully charged after being fully discharged during my vacation.
da oktohandout
@mactechplus has your answer. Maybe he will share it with us ;-)
da mayer
Same problem, but with a MacBook Air. Tried the solution you found, but it still won’t start up.
da Joseph Charpentier
What a miracle. Had two exact problem and Here in one post both of them is answered.Let me try this solutions. Mine was left for 8 days and when open it there was no charge. Now it wont charge though the battery capacity is still at 92 percent it shows replace immediately.
BTW, i tried reset SMC &NVRAM quite a few times and now the display autobrightness Sensor is not working. Any Idea!
da Kazi Upal
Mostra 1 altro commento
