Where is the IR sensor?
I'd like to attach an IR emitter to the front of the device, but I can't see where the IR sensor is located. The iFixit teardown doesn't offer any clues.
Questa è una buona domanda?
After some experimentation I found that the sensor is about half an inch to the left of the LED. Attaching my IR-extending emitter at that point led to reliable control of the device.
Unlike the gen 3 you can't see a hole even under a bright light, luckily found this thread @toddjonker has it spot on, 0.5" from the LED. Confirmed on the circuit image from the teardown (https://d3nevzfk7ii3be.cloudfront.net/ig...)
From my understanding the remote is using Bluetooth not IR as used in the older models.
Jump to Step 10 of the teardown {CSR (Qualcomm) CSR1010 Bluetooth radio}. If you look at Step 4 {Universal Scientific Industrial 339S00045 Wi-Fi module} you'll see the two antenna sockets one is for Bluetooth the other appears to be for WiFi (its possible this custom part is a dual Bluetooth transceiver so one can have two remotes active for game play).
Remember this model uses Siri and has a trackpad & accelerometer built into the remote. IR couldn't carry the data stream bi-directionally unlike Bluetooth.
The bottomline here is you don't need to worry about line of sight issues like you need to with IR. Here you just need to make sure the antenna is not blocked by metal.
This didn't answer the question; I did not ask about the remote's emitter. The new appleTV does in fact have an IR sensor as well as BT. I know this for a fact since I've been using the same non-BT Harmony remote as I used with earlier models.
As you hadn't expressed fully your direction here I answered the Q with the expectation you were planning on using the Apple remote that comes with the AppleTV not some other remote.
Dan, the question was clear. Your answer did not address the question.
grassview - Reread my answer where I clearly stated "From my understanding the remote is using Bluetooth not IR as used in the older models." You'll also see Christopher's answer points to the IR sensor.
Dan you didn’t answer the question , it’s ok you’re still a good person
As a sidebar, for anyone with a 5th gen Apple TV 4K, they now appear to have moved the IR receiver to the opposite end of the bezel, so this info is only correct for 4th Gen
What does that mean?
Start from the top (question), reading the related answers, and the meaning will be clear.
I can now control the volume of my Pioneer MCS-333 HTiB.
My understanding how Apple TV 4Gen learn my Pioneer (PR) remote is:
the box learned from PR;
the box will push the program to control the volume of Pioneer to Siri Remote (SR).
I thought the Apple TV system will learn the IR sequence from PR thru SR.
I had already tried turning off the Apple TV. SR can still pump up the volume or down the volume of my Pioneer.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 86
Tutti i Tempi: 65,340
