Salta al contenuto principale
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
111 Domande Visualizza tutte
Ear phones won't go into earphone hole
Can't get earphones in
Questa è una buona domanda?
Punteggio 3
5 Commenti
This was VERY helpful....!
Not being Tec savvy at all the thought of disassembling the Ipod was daunting ....and paying someone to open it to find the problem was not appealing ......
I took your advice and used a very thin needle and] it WAS lint....Didn't look like much but it was preventing the plug from going all the way in.
You made my day.
Thank You
Linette Burton
da
This worked for me too! I used the end of a paperclip and did a small scraping motion and then a pull-back and sweep! And ta-da! Tiniest belly button lint came out!
da
I am amazed but this worked for me too. I didn't see anything at all in the hole but I used a toothpick and just scraped it back and forth and all around and %#*@ if it didn't work!!! No one is more stunned than me!!
da
Thanks for the advice toothpick worked a treat
da
Same problem. Cleaned it out with a very thin screw driver. It's working. Thanks.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Check inside the audio jack with a flashlight. There may be a piece of lint or part of the plug from the last earphones you used stuck in there. Use a sewing needle or a very thin pair of tweezers to remove any foreign objects. If it doesn't work, the iPod will have to be disassembled and have the audio jack cleared out that way
Punteggio 9
11 Commenti:
Thank You!!! This helped A LOT! I was freaking out cause my earphones wouldn't go in. Then I looked up an answer and I found this. So thank you!
da
OMG! This is sooo good! I was looking everywhere for a solution and all it said was that i had to replace the audio jack. But then I found your answer and I looked inside and there was a huge ball of lint in there! Yay, I can enjoy my music again!!!
Thanks so much!
da
Oh my god my ipod has been sitting in my drawer broken for like 2 years now. I just so happened to take it out, wonder if it was really lost, and stumbled upon this. It actually worked and I now have an ipod again. Thank you!!
da
Thank you SO much, I nearly had a heart attack trying to fix it and there were tiny particles in there. I found that lightly using a tooth pick also helps. You were so helpful.
da
Thanks! I had pocket lint in my iPod. Got a jewelers screw driver, pulled it out, and voila. It is working again.
da
Mostra altri 6 commenti
I found my IPOD Nano earplug jack had cracked.how to repair my IPOD Nano Earplug Jack cracked to no cracked in so I can hear my IPOD nano through earplug again?
Punteggio 1
I am shocked I did the same thing. I was freaking out cause I use my iPhone 6 Plus and headphones A lot. There was a piece of lent inside my headphones jack hole thing. Took a paper clip and I got it out. Thank god!!!
Didn’t wanted to go to the Apple store
Punteggio 0
Aggiungi la tua risposta
Linette Burton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 16,268
