Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
I try to restore my iOS but get Error 48
I have tried to restore a phone i bought pre-owned, iTunes keeps giving me error 48. I have followed all the relevant guides but nothing works, is it a hardware fault... what do i need to replace. thanks, excellent videos and guides.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
In some cases error 48 can indicate, that your phone is not getting enough power from you phone which CAN indicate a solution by changing the u2 chip but I have to admit, that is a long shoot and might be complety wrong since I never delt with that error code on a 5s so far.
Punteggio 1
ERROR 48 SOLVED!!!!!
Hi,
Updating my 4S to IOS 8.4 was not succesful. Recovery using Itunes gave an Error 48.
Only fools do things over and over again and expect a different outcome.
So there I was being a fool trying recovery after recovery as suddenly I had an idee.
In my opinion there are 3 main factors: the hardware, the software and the test to make sure everything is working properly.
Hardware suddenly broke during update? I don't think so.
Software not OK? Not likely as the same software is already on millions devices.
Test not OK? Probably!
As I noticed being a fool, the Iphone was preparing, installing and testing and just before finishing gave Error 48. So the next time I tried, after the installation was finished and testing was about to end, I simply pulled the connection cord with my macbook and thus with Itunes. Now the testsoftware in Itunes, couldn't tell my Iphone he was not OK and he started just like that and is working properly ever since.
In this case, the patient was sic just because the doctor told him he was.
Maybe, there is something somewhere not 100% Ok, but if I can make calls, read mail, surf the net, use whatever app I tried so far, it is just a perfect working Iphone to me.
Punteggio 1
Aggiungi la tua risposta
Kenneth Johnston sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,696
