Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Can I replace an iPhone 5s screen with a iPhone 5 screen?
I have cracked my iPhone 5s screen. An iPhone 5 screen is a lot cheaper than a 5s screen. I know the home buttons are different, but I could care less about having touch-ID. So is it possible that I could put an iPhone 5 screen on a 5s?
Questa è una buona domanda?
Punteggio 42
8 Commenti
Thanks for useful informations.
da
thank you, the two phone look like each other in outside but are différente inside
da
can you do iphone 5c
da
Can i use 5s display on iphone 5...?
da
can i fixed iphone 5 board on 5s
da
Mostra altri 3 commenti
Aggiungi un commento
10 Risposte
Soluzione Prescelta
Unfortunately, you can't. They have different ribbon cable layouts.
Punteggio 31
5 Commenti:
can i put a iphone 5c screen on a iphone 5s ???
da
no you can't
da
I'm use 5s LCD on iPhone 5
da
can i put 5s disply on 5 motherboard
da
can i put a iphone 5 screen on a iphone 5s ???
da
Risposta Più Utile
Alex is correct. I fix iPhones professionally, and iPhone 5s screens cost 2-3 times more than iPhone 5 screens, at least the high quality ones. The ribbons and brackets are different.
If this was helpful at all, 'accept' my answer, or click the up arrow. :)
Punteggio 43
5 Commenti:
What about the digitizer
da
My iPhone 5s screen cracked . its a white iPhone with a white screen . can i replace the screen with a black iPhone 5s screen?
da
Yeah joe Ive done that the color has no effect on the actual product :)
da
What the main button on the 5S stay on the phone while changing the screen and if so when you put the 5 screen onto the 5S is would that be compatible what the 5S than still work with the 5 screen on it leaving the button with the 5S on it
da
Adakah sya boleh menggunakan skrin iphone 5c pada iphone 5s ?
da
No you can't, 5/5c/5s screens are not interchangeable.
Punteggio 12
2 Commenti:
how about the batteries
da
And how about the cameras
da
No, their flex ribbons are different.
Punteggio 4
Sadly no, one of the major different parts to the 5s and 5 screen is the home button layout one is more spaced out than the other when you place the home button plate over it . It overlaps and there isn't enough space for the ribbon cable and the little plate. NO NO NO NO NO
Punteggio 3
1 Commento:
da
Unfortunately NO,
The flex cable are different, so you cannot do that.
Sorry :)
Punteggio 3
%#*@ thanks y'all. - person who thought they could use a iPhone 5s screen on a iPhone 5.
Punteggio 1
Can i use ip5 volume button ribbon into ip5s?
Punteggio 0
Can I put a iPhone 5 screen on my iPhone 5s if I put my home button onto the iPhone 5 screen
Punteggio 0
We thought that both are same model (a lil difference)and we can replace screen of iPhone 5s with the iPhone 5 screen.
First of all, both the phones have different power cables attached with the screens.
Moreover, in iPhone 5s there’s fingerprint either of button so it will not set on it properly.
Answered by: Faadee
IG: iamfaadee
Punteggio 0
Aggiungi la tua risposta
Sanchez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 104
Tutti i Tempi: 184,880
