Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
799 Domande Visualizza tutte
White Plastic around charge port is broken and iPod won't dock.
Theres a piece of white plastic that surrounds the charge port on the Ipod. Half of the plastic broke off on mine and now the speaker dock won't detect it when docked. I can still connect it to the USB cable however. Does anyone know if this white plastic piece can be replaced?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
The broken plastic is most likely what allows/forces the connection to stay just where it should be. A cable/USB cable doesn't have the same problem as it's made to fit snug at any angle.
You may need to either find a replacement casing for the ipod, or put something on the dock that it can lean onto to be pushed back to where it should be. It only needs to be a tiny amount off center to not be able to work properly.
Punteggio 1
Blake, the plastic bezel part is available at places like this and many others. Hope this helps, good luck.
Punteggio 1
Aggiungi la tua risposta
Blake sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 249
