Salta al contenuto principale
GoPro Hero3+ Black Edition Front Face Plate Replacement
Cosa ti serve
  1. GoPro Hero3+ Black Edition Front Face Plate Replacement, Front Face Plate: passo 1, immagine 1 di 2 GoPro Hero3+ Black Edition Front Face Plate Replacement, Front Face Plate: passo 1, immagine 2 di 2
    • Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
    • To avoid breaking or weakening the tabs on the face plate which hold it in place, alternate the sides from which you pry and check each tab before separating the plate from the body.
Conclusione
To reassemble your device, press face plate back on with hands.
Nathan Braham
Membro da: 04/14/15
110 Reputazione
1 Guida realizzata
Cal Poly, Team 6-15, Maness Spring 2015 Membro di Cal Poly, Team 6-15, Maness Spring 2015
CPSU-MANESS-S15S6G15
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,647
