Salta al contenuto principale
Acer Aspire 4810TZ-4120 Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire 4810TZ-4120 Hard Drive Replacement, Hard drive: passo 1, immagine 1 di 2 Acer Aspire 4810TZ-4120 Hard Drive Replacement, Hard drive: passo 1, immagine 2 di 2
    • Lay the laptop upside down.
    • Locate and unscrew the seven phillips head screws.
  2. Acer Aspire 4810TZ-4120 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Remove the cover panel from the laptop
  3. Acer Aspire 4810TZ-4120 Hard Drive Replacement: passo 3, immagine 1 di 3 Acer Aspire 4810TZ-4120 Hard Drive Replacement: passo 3, immagine 2 di 3 Acer Aspire 4810TZ-4120 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Remove the hard drive from the laptop by using a Spudger tool to pry it out.
Conclusione
Un commento
Yes, but how do you get the hard drive out of its carrier, for example in order to replace it with an SSD?
Philip Le Riche - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 499
