iPhone Needs a Force Restart
Your iPhone may simply be temporarily frozen and needs a manual reset or “force restart.” Follow the appropriate instructions to force restart your iPhone.
Dead Battery
If your battery is completely drained of charge, your iPhone may not immediately turn on even when plugged into a power source. Connect your iPhone to a charger and let it charge for 30 minutes, and then try turning it on again.
Dirty Charging Port or Cable
If the iPhone still doesn’t turn on after 30 minutes connected to power, check the charging port and cable and make sure they’re clean. If the charging port is clogged with debris or the charging cable contacts are dirty, this can prevent the battery from charging. Clean the port carefully with a toothpick or any other non-conductive probe similar to a spudger, and a little isopropyl alcohol, let it dry, and try a different charging cable. Alternatively, try charging your iPhone wirelessly.
Faulty Battery or Charging Port
If the iPhone still doesn’t turn on, it may have a dead battery or a bad charging port. Replace the battery with a partially charged one and see if the phone will turn on. If not, there may be a power button or logic board issue. If the phone does turn on, plug it in and see if the charging indication comes on. If the phone says it is charging, then the Lightning connector works, and you likely had a bad battery. But if it still doesn’t charge, you may need to replace the Lightning connector with a quality replacement.
Bad Power Button
If the power button doesn't seem to work, plug the iPhone into a power source and see if it turns on automatically. If the phone turns on and has power, then there might be a problem with either the power button or the power button cable. Test the power button and replace it if necessary.
Bad Display
It’s possible that it appears nothing is happening because the display is bad. An easy way to test this is to turn the phone on and listen for a sound. Also, you can move the mute toggle switch back and forth to see if it vibrates. If it vibrates or you hear a sound but nothing displays on the screen, then the screen is most likely the problem. Try replacing it and see if the display is still black.
You can purchase a new display assembly here, and follow the appropriate screen replacement guide for your phone.
Bad Logic Board
If none of the above solutions does the trick, your logic board may be faulty and needs to be replaced. You can either replace the entire board or attempt to diagnose and repair it using microsoldering techniques. That is a whole 'nother beast!
If you’re interested in learning board-level repair, you can start your investigation here! You can also get the materials to practice microsoldering here.
Questions other people have asked about this
- My iPhone will not turn on after several hours of charging. HELP?
- iPhone 6 died suddenly and won't turn on.
- iPhone won't turn on after screen replacement?
12 Commenti
my iphone is not turn on
novanjithanusara - Replica
my iphone 6 plus is charging but it wont turn on and it had died on 14
Jalya Johnson-Scott - Replica
my phone turned off on its own and wont turn bck on i tried charging it and it only shows charging icon but not turning on
icyy beenlit - Replica
did u fix it now? i have the same problem at the moment i need to know what u did, if you can tell me please, thx
tanko maria -
my iphone will not turn on it on the charger right now
Alicia - Replica
