Salta al contenuto principale
Repair and service information related to the ResMed AirSense 10 CPAP machine. Also known as the ResMed Air10.
28 Domande Visualizza tutte
My humidifier heater isn't working.
My Airsense 10 is about 2 years old. My humidifier heater quit. I pulled the cover and checked the fuse and it is good. I don't have a schematic to check the test points. Could you give me some info on the heater?
Thanks!
Questa è una buona domanda?
Punteggio 0
1 Commento
Yes this is the fuse under the heater plate. I unclipped it to test its continuity.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Bg Higg by checked the fuse I assume your are referring to the one under the heater unit like shown on here Data on the heater is not freely available so I would go ahead and replace the heater on use a bench power supply to see if that could run the heater.
Punteggio 1
Aggiungi la tua risposta
Bg Higg sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 358
