Salta al contenuto principale
The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
90 Domande Visualizza tutte
JBL Charge 3 won't turn OFF (and stay off)
Have a JBL Charge 3 I bought 13 months ago. Last week it was kicked into the pool courtesy of my 5 year old. It saw water on all sides as it rolled, it floated, and was never fully submerged, the rear flap covering the charge ports etc was securely closed.
Since then, it won't power OFF (and stay off). I push the power button and all the usual sounds play and it turns off. However within 5 seconds it turns itself back on and will reconnect to my phone via BT.
Has the same issue if attached to power or running off battery. It's been on 4 days now and still has plenty of charge. Still works, just not optimal and a bit frustrating.
Hopefully someone has an idea of what might be going on.
Cheers.
Questa è una buona domanda?
Punteggio 3
8 Commenti
My jbl charge 3 does not want to run. It just goes off when I unplug it from the charger
da
Hallo meine Charge 3 lässt sich nicht einschalten gibs da auch ein reset Befehl. Mfg kai
da
I have same problem but on charge 4 how off it? Please help I'm sleeping and the speaker turns on
da
I have been trying to turn off my jbl 4 speaker but it’s not going off. I pressed but the plus volume button at the same time with the play/pause button, yet it’s not shutting down.. please should I do?
da
I have an Xtreme 2 which won't shut off nor will it do a hard reset (+ and ∆) ….
So like an idiot I bought a second one and now they both won't work or shut off ???
Any help appreciated
da
Mostra altri 3 commenti
Aggiungi un commento
5 Risposte
Risposta Più Utile
Hold power button and play button about 10 seconds till the Charge3 shuts itself. You will hear the speakers “click" off. This will power it down completely without resetting the bluetooth. When i do this it keeps the charge3 off, but when i turn it back on, i have to do the power/play buutton 10 sec hold every time. Its like my power button needs reset every time i use it.
Punteggio 2
3 Commenti:
Worked perfect. I had a solid power light on and nothing would work. Tried the reset with + and > buttons multiple times. Pressing the power and > buttons simultaneously for 10 seconds worked.
da
Ty so much that work
da
Worked on the Charge 4. Why isn't this in the manual?
da
Try doing a reset:
· Power ON the device, then press and hold the "Volume+" and the "Play/Pause" buttons at the same time. When the device switches off after a few seconds, sounding the OFF prompt, it has been reset.
· After performing the master reset in your speaker, please delete/unpair the JBL Charge 3 bluetooth history in your device (phone/laptop/tablet) and re-connect.
This reset is also a great way to get rid of any annoying (interfering) connected devices after too many of your buddies have used your speaker to play their music.
Punteggio 1
6 Commenti:
Thanx, I was wondering why would someone reset the charge 3 to begin with but now I know based on your answer
da
For me is same like on jbl charge 4 now it nervous me and my fathers so imb gonna remove battery cause no information for it
da
I have reset these buds more than once they disconnect from one another and now the lights stay on. I wouldn't recommend these to anyone. I wish I could return them since I still have time but because of COVID19 I cannot.
da
I have followed these steps and there is no way I can turn it off unless I force it for about 10 seconds, my device is new, it literally has less than one day of use, I provided it yesterday and today I began to see that it no longer responded the same. If there is any answer for that I would appreciate it ..
da
I keep trying and it refuses to turn off until the battery dies..I hadn’t noticed that it wAs staying in but I’ve had to charge it a lot more often than I used to do it must have been staying on
da
Mostra 1 altro commento
I am experiencing the same issue with my charge 4. I can’t get a good night sleep with the speaker turning on/ restarting by itself. its so annoying. it wakes me up in the middle of the night with its booting sound. such a waste of money.
Punteggio 0
Put it to charge for at least 8 hours. This will force close your JBL device and then once you start it again it will work properly. Tested and worked for me.
Punteggio 0
So i tried to reset mine and it didn’t do anything. So i just kept on pressing the power button and the button that connects your speaker to other speakers and it just randomly turned off. A miracle
Punteggio 0
Aggiungi la tua risposta
Grant sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 136
Tutti i Tempi: 38,411
