Salta al contenuto principale
TiVo Series 2 TCD24008A Power Supply Replacement
Cosa ti serve
  1. TiVo Series 2 TCD24008A Power Supply Replacement, Cover: passo 1, immagine 1 di 1
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Power Supply Replacement: passo 2, immagine 1 di 1
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Power Supply Replacement: passo 3, immagine 1 di 1
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Power Supply Replacement, Power Supply: passo 4, immagine 1 di 1
    • Locate the power supply.
  5. TiVo Series 2 TCD24008A Power Supply Replacement: passo 5, immagine 1 di 1
    • Remove the belt connecting the power supply to the motherboard by pulling it out.
  6. TiVo Series 2 TCD24008A Power Supply Replacement: passo 6, immagine 1 di 1
    • Remove the red, yellow, and black cable connecting the power supply to the hard drive.
  7. TiVo Series 2 TCD24008A Power Supply Replacement: passo 7, immagine 1 di 1
    • Remove the two 0.31 inch T-9 screws from the power supply.
  8. TiVo Series 2 TCD24008A Power Supply Replacement: passo 8, immagine 1 di 2 TiVo Series 2 TCD24008A Power Supply Replacement: passo 8, immagine 2 di 2
    • Pinch the plastic plugs and lift the power supply up to detach from plugs.
    • All 4 plugs must be detached to remove power supply.
Conclusione
Phil Jones
Membro da: 10/11/11
41 Reputazione
1 Guida realizzata
Cal Poly, Team 5-33, Amido Fall 2011 Membro di Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,209
