Salta al contenuto principale
iMac Intel 21.5" EMC 2308 Audio Ports Replacement
Cosa ti serve
  1. iMac Intel 21.5" EMC 2308 Audio Ports Replacement, Glass Panel: passo 1, immagine 1 di 2 iMac Intel 21.5" EMC 2308 Audio Ports Replacement, Glass Panel: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Compra
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  2. iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 2, immagine 1 di 2 iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 2, immagine 2 di 2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. iMac Intel 21.5" EMC 2308 Audio Ports Replacement, Display: passo 3, immagine 1 di 3 iMac Intel 21.5" EMC 2308 Audio Ports Replacement, Display: passo 3, immagine 2 di 3 iMac Intel 21.5" EMC 2308 Audio Ports Replacement, Display: passo 3, immagine 3 di 3
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
  4. iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 4, immagine 1 di 1
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board.
  5. iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 5, immagine 1 di 3 iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 5, immagine 2 di 3 iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 5, immagine 3 di 3
    • Pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
    • The vertical sync ribbon cable has a ZIF style end, but the socket has no lock or retaining flap. Simply pull the cable away from its socket toward the optical drive side of the iMac to disconnect it from the LED driver board.
  6. iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 6, immagine 1 di 3 iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 6, immagine 2 di 3 iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 6, immagine 3 di 3
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
  7. iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 7, immagine 1 di 1
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
    • Be careful when disconnecting and reconnecting this cable, as it is easily damaged.
  8. iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 8, immagine 1 di 1
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
  9. iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 9, immagine 1 di 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
  10. iMac Intel 21.5" EMC 2308 Audio Ports Replacement, Audio Ports: passo 10, immagine 1 di 2 iMac Intel 21.5" EMC 2308 Audio Ports Replacement, Audio Ports: passo 10, immagine 2 di 2
    • Disconnect the audio port cable by pulling its connector toward the right side of the iMac.
    • De-route the audio port cable from the outer case.
  11. iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 11, immagine 1 di 2 iMac Intel 21.5" EMC 2308 Audio Ports Replacement: passo 11, immagine 2 di 2
    Compra
    • Remove two T10 Torx screws securing the audio ports to the outer case.
    • Lift the audio ports out of the outer case.
    • A pair of tweezers is helpful to put the ports back in place. First insert the lower tab into the bracket on the outer case, then fasten the screw to secure the jack to the outer case.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 7,119
