Salta al contenuto principale
iMac G5 20" Model A1145 RAM Replacement
Cosa ti serve
  1. iMac G5 20" Model A1145 RAM Replacement, Access Door: passo 1, immagine 1 di 1
    • Orient the iMac face-side down on a table with the bottom edge facing yourself.
    • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
    • The screws are captive in the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. iMac G5 20" Model A1145 RAM Replacement: passo 2, immagine 1 di 1
    • Remove the access door.
  3. iMac G5 20" Model A1145 RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Insert your fingers into the two RAM arms and pull both arms toward yourself to eject the RAM chip.
  4. iMac G5 20" Model A1145 RAM Replacement: passo 4, immagine 1 di 1
    • Slide the RAM chip straight out of its socket.
    • Make sure both RAM arms are fully rotated outward before reinstalling your RAM chip.
Conclusione
Altre 13 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 20,915
