Salta al contenuto principale
iMac G5 17" Model A1144 RAM Replacement
Cosa ti serve
  1. iMac G5 17" Model A1144 RAM Replacement, Access Door: passo 1, immagine 1 di 1
    • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • These screws are captive in the access door.
  2. iMac G5 17" Model A1144 RAM Replacement: passo 2, immagine 1 di 1
    • Remove the access door from your iMac.
  3. iMac G5 17" Model A1144 RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Insert your fingers into the two RAM arms and pull both arms toward yourself to eject the RAM chip.
  4. iMac G5 17" Model A1144 RAM Replacement: passo 4, immagine 1 di 1
    • Slide the RAM chip straight out of its socket.
    • Make sure both RAM arms are fully rotated outward before reinstalling your RAM chip.
Conclusione
Altre 12 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 17,170
