Salta al contenuto principale
iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement
Cosa ti serve
  1. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement, M.2 NVMe Drive: passo 1, immagine 1 di 2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement, M.2 NVMe Drive: passo 1, immagine 2 di 2
    • Lay the desktop on its side with the glass panel facing up.
    • Remove the single screw.
  2. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: passo 2, immagine 1 di 2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: passo 2, immagine 2 di 2
    • Remove the glass side by pivoting it up with the bottom side still seated in the notches.
    • Lift the glass side out of the notches and set it to the side.
  3. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: passo 3, immagine 1 di 3 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: passo 3, immagine 2 di 3 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: passo 3, immagine 3 di 3
    • Locate the M.2 drive that is right above the CPU.
    • Remove the screw on the edge of the drive.
  4. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: passo 4, immagine 1 di 2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: passo 4, immagine 2 di 2
    • The drive should lift up on the edge where the screw was.
    • Pull the drive out at an angle from the motherboard.
  5. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: passo 5, immagine 1 di 2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: passo 5, immagine 2 di 2
    • Line the new drive up with the slot and gently slide it in.
    • Use one finger to hold the drive down while you screw it back in.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Thank you, Kilie, for the clear step-by-step instructions, together with pictures, for NVMe SSD installation.
George
George Meier - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 119
Tutti i Tempi: 2,640
