Salta al contenuto principale
eMac AirPort Card Replacement
Cosa ti serve
  1. eMac AirPort Card Replacement, AirPort Card: passo 1, immagine 1 di 1
    • Installation of the AirPort Card on this machine is very easy.
    • The AirPort slot is located just above the Optical Drive in the front of the unit. It is covered by a small plastic panel.
  2. eMac AirPort Card Replacement: passo 2, immagine 1 di 2 eMac AirPort Card Replacement: passo 2, immagine 2 di 2
    • Press the eject arrow located on the upper right corner of your keyboard. Once the optical drive tray is open, gently hold it and shut down the machine.
    • Remove the two Phillips screws located to the right and left sides of the optical drive tray.
    • The Airport cable is snapped into place on the back of the optical drive panel .
    • Gently remove the panel from the front of the eMac
    • Disconnect the AirPort cable from the optical drive panel.
    • Pull the AirPort card straight away from its socket in the eMac.
  3. eMac AirPort Card Replacement: passo 3, immagine 1 di 2 eMac AirPort Card Replacement: passo 3, immagine 2 di 2
    • Slide the new AirPort card into the slot until its firmly seated.
    • Reconnect the AirPort cable to the optical drive panel.
    • Reattach the optical drive panel and restart the eMac.
    • To configure the AirPort card, go under the Apple in the upper left hand corner to System Preferences - Network. The AirPort option should be on the left hand window. Select it.
    • It should set up on its own. If not hit the "Assist Me" box on the bottom of the page.
Conclusione
Altre 19 persone hanno completato questa guida.
mayer
Membro da: 01/04/10
685.580 Reputazione
12 Guide realizzate
MacHale Enterprises Membro di MacHale Enterprises
Business
1 Membro
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 26,812
