Salta al contenuto principale
Westcott iPoint Evolution Outer Casing Replacement
Cosa ti serve
  1. Westcott iPoint Evolution Outer Casing Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Step 1: Start with the back of the pencil sharpener facing you.
    • This allows you to locate the power source.
  2. Westcott iPoint Evolution Outer Casing Replacement: passo 2, immagine 1 di 1
    • Step 2: Grab the end of the plug located at the bottom of the sharpener and pull it out gently.
  3. Westcott iPoint Evolution Outer Casing Replacement: passo 3, immagine 1 di 2 Westcott iPoint Evolution Outer Casing Replacement: passo 3, immagine 2 di 2
    • There are three parts of the sharpener.
    • Step 3: Grab the very top of the sharpener, twist it to the right and lift it up to remove it.
  4. Westcott iPoint Evolution Outer Casing Replacement: passo 4, immagine 1 di 3 Westcott iPoint Evolution Outer Casing Replacement: passo 4, immagine 2 di 3 Westcott iPoint Evolution Outer Casing Replacement: passo 4, immagine 3 di 3
    • Step 4: Grab the center of the sharpener and lift it up to remove the piece.
  5. Westcott iPoint Evolution Outer Casing Replacement: passo 5, immagine 1 di 3 Westcott iPoint Evolution Outer Casing Replacement: passo 5, immagine 2 di 3 Westcott iPoint Evolution Outer Casing Replacement: passo 5, immagine 3 di 3
    • Step 5: Remove the small ring that is around the sharpener.
    • This piece is below the center of the sharpener that you just removed.
  6. Westcott iPoint Evolution Outer Casing Replacement: passo 6, immagine 1 di 1
    • Step 6: Flip the pencil sharpener upside down.
    • Locate the four screws on the bottom of the sharpener.
  7. Westcott iPoint Evolution Outer Casing Replacement: passo 7, immagine 1 di 1
    • Step 7: Take a screwdriver and unscrew all of the screws on the bottom.
  8. Westcott iPoint Evolution Outer Casing Replacement: passo 8, immagine 1 di 1
    • Step 8: After all the screws are removed gently take off the bottom of the sharpener.
  9. Westcott iPoint Evolution Outer Casing Replacement: passo 9, immagine 1 di 1
    • Step 9: Carefully lift the lid off of the sharpener.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 43
Tutti i Tempi: 11,790
