Salta al contenuto principale
Wall Outlet Cover Replacement
Cosa ti serve
  1. Wall Outlet Cover Replacement, Wall Outlet Cover: passo 1, immagine 1 di 3 Wall Outlet Cover Replacement, Wall Outlet Cover: passo 1, immagine 2 di 3 Wall Outlet Cover Replacement, Wall Outlet Cover: passo 1, immagine 3 di 3
    • Remove any hazardous pieces from previous cover.
    • Be sure to remove the two flathead screws to remove any debris, rather than trying to pull off the sharp pieces.
  2. Wall Outlet Cover Replacement: passo 2, immagine 1 di 3 Wall Outlet Cover Replacement: passo 2, immagine 2 di 3 Wall Outlet Cover Replacement: passo 2, immagine 3 di 3
    • Insert any cable or cables that may be hanging out inside of the wall hole.
    • Making a loop in the cable might be helpful to push it inside the wall.
  3. Wall Outlet Cover Replacement: passo 3, immagine 1 di 1
    • Insert two screws into the holes of the new wall cover.
  4. Wall Outlet Cover Replacement: passo 4, immagine 1 di 3 Wall Outlet Cover Replacement: passo 4, immagine 2 di 3 Wall Outlet Cover Replacement: passo 4, immagine 3 di 3
    • Line up the screws in the plate with the screw holes in the wall.
    • Tighten the screws slightly with your hands to ensure that both screws have found the proper holes.
    • Once the screws have been tightened enough to stay in the holes, they should hold the outlet cover in place.
  5. Wall Outlet Cover Replacement: passo 5, immagine 1 di 3 Wall Outlet Cover Replacement: passo 5, immagine 2 di 3 Wall Outlet Cover Replacement: passo 5, immagine 3 di 3
    • Tighten the two screws with a flathead screwdriver.
  6. Wall Outlet Cover Replacement: passo 6, immagine 1 di 3 Wall Outlet Cover Replacement: passo 6, immagine 2 di 3 Wall Outlet Cover Replacement: passo 6, immagine 3 di 3
    • Double check that the wall cover plate does not have a gap, and it is completely attached to the wall.
    • If any gap is detected, push the plate to the wall and continue to tighten the screws until the gap completely closes.
Conclusione
Leydi Navarrete
Membro da: 04/12/21
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 57
Tutti i Tempi: 1,103
