Salta al contenuto principale
Volleyball Valve Replacement
Cosa ti serve
  1. Volleyball Valve Replacement, Valve: passo 1, immagine 1 di 1
    • Bend a thin metal wire into a hook.
    • This is what we will be using to wiggle the air valve out.
  2. Volleyball Valve Replacement: passo 2, immagine 1 di 1
    • Insert the wire into the valve and use it to hook and pull out the valve as much as possible. .
    • This process might take awhile depending how broken the valve is.
  3. Volleyball Valve Replacement: passo 3, immagine 1 di 1
    • Once a piece of the valve is sticking out, use the needle nose pliers to pull out the valve.
  4. Volleyball Valve Replacement: passo 4, immagine 1 di 1
    • With your new valve, place it to the hole where the previous valve was, and use the screwdriver to push it in until it is flush with the surface of the ball.
  5. Volleyball Valve Replacement: passo 5, immagine 1 di 1
    • You are done! The volleyball valve has been replaced and should not let any air out.
Conclusione
Justin Nadela
Membro da: 01/16/22
121 Reputazione
1 Guida realizzata
Un commento
Thanks for this!!
Can you please let me know what valves to buy?
(my email address is sendtojfk@gmail.com)
Thanks!
Justin Kern - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 124
Tutti i Tempi: 2,937
