Salta al contenuto principale
Vacuum Cleaner Brush Roll Replacement
Cosa ti serve
  1. Vacuum Cleaner Brush Roll Replacement, Brush Roll: passo 1, immagine 1 di 1
    • Be sure to unplug the device from the wall outlet before disassembling.
    • Remove the bottom head of the vacuum cleaner by pressing the push button.
  2. Vacuum Cleaner Brush Roll Replacement: passo 2, immagine 1 di 2 Vacuum Cleaner Brush Roll Replacement: passo 2, immagine 2 di 2
    • Carefully unscrew the 6 screws with a Phillips screwdriver. Set aside.
  3. Vacuum Cleaner Brush Roll Replacement: passo 3, immagine 1 di 1
    • Separate the top portion of the head from the bottom.
    • Make sure not to pull off or damage the connected wires.
  4. Vacuum Cleaner Brush Roll Replacement: passo 4, immagine 1 di 1
    • Slip off the belt.
  5. Vacuum Cleaner Brush Roll Replacement: passo 5, immagine 1 di 2 Vacuum Cleaner Brush Roll Replacement: passo 5, immagine 2 di 2
    • Pull the brush roll from its slots.
  6. Vacuum Cleaner Brush Roll Replacement: passo 6, immagine 1 di 2 Vacuum Cleaner Brush Roll Replacement: passo 6, immagine 2 di 2
    • Use scissors to cut strings and other debris from the brush roll. Avoid cutting the bristles.
  7. Vacuum Cleaner Brush Roll Replacement: passo 7, immagine 1 di 1
    • Return the clean brush roll and re-situate the belt to secure it in place.
Conclusione
To reassemble your device, follow the disassembly instructions in reverse order.
Kaitlyn Sheets
Membro da: 01/19/16
117 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 63
Tutti i Tempi: 2,539
