Salta al contenuto principale
Tommy Hilfiger Quartz Watch Band Link Replacement
Cosa ti serve
  1. Tommy Hilfiger Quartz Watch Band Link Replacement, Band Link: passo 1, immagine 1 di 1
    • Place the watch on your wrist and approximate the number of links to be removed.
  2. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 2, immagine 1 di 1
    • Identify the arrows located directly on the links and point them downwards in the south position.
  3. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 3, immagine 1 di 3 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 3, immagine 2 di 3 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 3, immagine 3 di 3
    • Lay and secure the wristband on the watchband holder.
  4. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 4, immagine 1 di 3 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 4, immagine 2 di 3 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 4, immagine 3 di 3
    • Align the tip of the pin pusher on the pin.
    • Begin tapping the hammer with force to push the link pin out.
  5. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 5, immagine 1 di 2 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 5, immagine 2 di 2
    • Set aside the link pins and links that have been removed from the watch.
  6. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 6, immagine 1 di 3 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 6, immagine 2 di 3 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 6, immagine 3 di 3
    • In order to add links to the wristband, ensure that the arrows are pointing upwards in the north position.
    • Secure the wristband on the watchband holder.
  7. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 7, immagine 1 di 2 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 7, immagine 2 di 2
    • Align the link pins to be added on the holes that connect the desired link to the wristband.
  8. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 8, immagine 1 di 3 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 8, immagine 2 di 3 Tommy Hilfiger Quartz Watch Band Link Replacement: passo 8, immagine 3 di 3
    • Use the hammer to gently tap the link pins into the holes until the pin is completely resting in position.
  9. Tommy Hilfiger Quartz Watch Band Link Replacement: passo 9, immagine 1 di 1
    • Finally, place the watch on your wrist to determine if the links are secure and the fitment is comfortable.
    • If adjustments need to be made, refer to step 2 for the subtraction of links and step 6 for the addition of links.
Linea Traguardo
Ayush Theyyil
Membro da: 09/14/21
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 79
Tutti i Tempi: 6,086
