Salta al contenuto principale
Teddy Bear Nose Replacement
Cosa ti serve
  1. Teddy Bear Nose Replacement, Nose: passo 1, immagine 1 di 2 Teddy Bear Nose Replacement, Nose: passo 1, immagine 2 di 2
    • Rip out about five inches of stitches from around the bear's snout.
  2. Teddy Bear Nose Replacement: passo 2, immagine 1 di 2 Teddy Bear Nose Replacement: passo 2, immagine 2 di 2
    • Remove stuffing from around the bear's snout.
  3. Teddy Bear Nose Replacement: passo 3, immagine 1 di 1
    • Flip the fabric of the snout inside out to expose the back of the plastic nose.
  4. Teddy Bear Nose Replacement: passo 4, immagine 1 di 2 Teddy Bear Nose Replacement: passo 4, immagine 2 di 2
    • Remove the plastic backing of the teddy bear's nose (if it's still there). You may have to use pliers.
  5. Teddy Bear Nose Replacement: passo 5, immagine 1 di 1
    • Pull the nose out of the front of the teddy bear’s face.
  6. Teddy Bear Nose Replacement: passo 6, immagine 1 di 1
    • Push the front of the new nose through the existing hole in the teddy bear’s face.
  7. Teddy Bear Nose Replacement: passo 7, immagine 1 di 1
    • Attach the nose backing on the inside of the teddy bear’s nose.
  8. Teddy Bear Nose Replacement: passo 8, immagine 1 di 1
    • Restuff the teddy bear’s nose with the stuffing you took out.
    • You may need to add more stuffing if the bear’s nose looks flat or deflated.
  9. Teddy Bear Nose Replacement: passo 9, immagine 1 di 1
    • Thread the needle with about 18 inches of thread the same color as the bear's fur or stitches.
  10. Teddy Bear Nose Replacement: passo 10, immagine 1 di 3 Teddy Bear Nose Replacement: passo 10, immagine 2 di 3 Teddy Bear Nose Replacement: passo 10, immagine 3 di 3
    • Sew the teddy bear’s face using a whip stitch until the opening is completely closed.
    • For help with sewing a whip stitch, follow this guide: How to Sew a Whip Stitch.
  11. Teddy Bear Nose Replacement: passo 11, immagine 1 di 2 Teddy Bear Nose Replacement: passo 11, immagine 2 di 2
    • Once the face is completely sewn shut, knot the end of the thread, and cut off the excess.
Linea Traguardo
Nazib Khan
Membro da: 09/28/21
193 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 59
Tutti i Tempi: 3,876
