Salta al contenuto principale
Sticky Key Saxophone Fix
Cosa ti serve
  1. Sticky Key Saxophone Fix, Sticky Key Saxophone Fix: passo 1, immagine 1 di 1
    • Locate sticking key.
  2. Sticky Key Saxophone Fix: passo 2, immagine 1 di 1
    • Screws are located down from key.
  3. Sticky Key Saxophone Fix: passo 3, immagine 1 di 1
    • Loosen screw slowly and carefully, so that screw isn't lost.
  4. Sticky Key Saxophone Fix: passo 4, immagine 1 di 1
    • Test key and note free movement.
  5. Sticky Key Saxophone Fix: passo 5, immagine 1 di 1
    • Put saxophone completely together and test out key.
    • If key still sticks repeat previous steps.
Conclusione
Loosen screw until key moves freely or as desired. Once as desired, you are then ready to play the instrument and test out key!
AlysonStrange
Membro da: 05/30/17
101 Reputazione
1 Guida realizzata
Un commento
An Issue I have with a sticky key on my Alto Saxophpone. I found a remedy on ifixit.com, a hack recommended for fixing pretty much anything! Try it out!!
kwiggins01 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,801
