Salta al contenuto principale
Sprinkler Head Replacement
Cosa ti serve
  1. Sprinkler Head Replacement, Sprinkler Head: passo 1, immagine 1 di 1
    • Turn off the water supply to the sprinklers.
    • This process will vary depending on your sprinkler controller.
  2. Sprinkler Head Replacement: passo 2, immagine 1 di 1
    • Find where the water supply feeds the sprinkler system and close the valve in the event of emergency or unforeseen circumstances.
  3. Sprinkler Head Replacement: passo 3, immagine 1 di 1
    • Dig a hole down to the base of the sprinkler head.
    • Be careful to avoid puncturing the sprinkler line.
  4. Sprinkler Head Replacement: passo 4, immagine 1 di 1
    • Using your hand or a gardening trowel, finish digging so that the sprinkler head is fully visible and is clear of dirt and debris.
  5. Sprinkler Head Replacement: passo 5, immagine 1 di 2 Sprinkler Head Replacement: passo 5, immagine 2 di 2
    • Unscrew the sprinkler head from the line it is attached to.
    • If is loose enough you may not need pliers.
  6. Sprinkler Head Replacement: passo 6, immagine 1 di 2 Sprinkler Head Replacement: passo 6, immagine 2 di 2
    • Coat the threads of the water line with teflon tape to avoid leaking.
  7. Sprinkler Head Replacement: passo 7, immagine 1 di 2 Sprinkler Head Replacement: passo 7, immagine 2 di 2
    • Using your hand, screw the new sprinkler head on over the teflon tape.
    • Once the sprinkler head is hand tight, use pliers to tighten it by another half turn.
  8. Sprinkler Head Replacement: passo 8, immagine 1 di 1
    • Fill the hole in and pack it down to avoid unwanted movement of the new sprinkler head.
  9. Sprinkler Head Replacement: passo 9, immagine 1 di 1
    • Turn the sprinkler system on.
  10. Sprinkler Head Replacement: passo 10, immagine 1 di 1
    • Twist the top of the sprinkler until it is aimed where you want it.
  11. Sprinkler Head Replacement: passo 11, immagine 1 di 1
    • Use a flat head screwdriver to adjust the flow of water if needed.
    • Turning right decreases the water flow. Turning left increases the water flow.
Conclusione
Enjoy your green lawn and water savings.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 45
Tutti i Tempi: 441
