Salta al contenuto principale
Sony Vaio Tap 11 Power Jack Replacement
Cosa ti serve
  1. Sony Vaio Tap 11 Power Jack Replacement, Screen Assembly: passo 1, immagine 1 di 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Power Jack Replacement: passo 2, immagine 1 di 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Power Jack Replacement: passo 3, immagine 1 di 2 Sony Vaio Tap 11 Power Jack Replacement: passo 3, immagine 2 di 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Power Jack Replacement, Battery: passo 4, immagine 1 di 1
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Power Jack Replacement: passo 5, immagine 1 di 1
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
  6. Sony Vaio Tap 11 Power Jack Replacement, Power Jack: passo 6, immagine 1 di 1
    • Remove the two 3mm Phillips #000 screws from the bottom left corner of the device.
  7. Sony Vaio Tap 11 Power Jack Replacement: passo 7, immagine 1 di 1
    • Unplug the jack from the motherboard.
  8. Sony Vaio Tap 11 Power Jack Replacement: passo 8, immagine 1 di 1
    • Remove the metal covering.
  9. Sony Vaio Tap 11 Power Jack Replacement: passo 9, immagine 1 di 1
    • Pull out the cable and jack assembly.
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team 1-2, Harley Fall 2015 Membro di IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Membri
20 Guide realizzate
2 Commenti
I wonder if you have the part number or can supply this power jack?
James Toal - Replica
Yes, Where can I find this replacement part?
mikebeard65 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,790
