Salta al contenuto principale
Sony Reader Touch Edition PRS-600 Power Button Replacement
Cosa ti serve
  1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Back Panel: passo 1, immagine 1 di 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 2, immagine 1 di 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 3, immagine 1 di 1
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 Power Button Replacement, Battery: passo 4, immagine 1 di 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 5, immagine 1 di 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
  6. Sony Reader Touch Edition PRS-600 Power Button Replacement, Power Button: passo 6, immagine 1 di 1
    • Remove the stylus from the device.
  7. Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 7, immagine 1 di 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 7, immagine 2 di 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: passo 7, immagine 3 di 3
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
Conclusione
Clemson, Team 1-4, Benson Fall 2014 Membro di Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 580
