Salta al contenuto principale
Sony DSC-HX50V Lens Replacement
Cosa ti serve
  1. Sony DSC-HX50V Lens Replacement, Lens: passo 1, immagine 1 di 3 Sony DSC-HX50V Lens Replacement, Lens: passo 1, immagine 2 di 3 Sony DSC-HX50V Lens Replacement, Lens: passo 1, immagine 3 di 3
    • Remove the camera's battery.
    • Unscrew the three screws using a Phillips #00 screwdriver.
    • Unscrew the two screws on the left side of the camera.
    • Unscrew the remaining two screws on the opposing side of the camera.
  2. Sony DSC-HX50V Lens Replacement: passo 2, immagine 1 di 3 Sony DSC-HX50V Lens Replacement: passo 2, immagine 2 di 3 Sony DSC-HX50V Lens Replacement: passo 2, immagine 3 di 3
    • Gently pull the frame off the LCD screen, outwards and upwards from the bottom of the camera and remove it.
  3. Sony DSC-HX50V Lens Replacement: passo 3, immagine 1 di 2 Sony DSC-HX50V Lens Replacement: passo 3, immagine 2 di 2
    • Gently push the board up from the bottom. This will release the first metal prong.
    • Gently push the board to the right from the right side. This will release the second metal prong.
    • The board will flip open to the right once released from both prongs.
    • Be gentle.
  4. Sony DSC-HX50V Lens Replacement: passo 4, immagine 1 di 1
    • With needle nose pliers, gently bend back the metal tab at the bottom of the click wheel PCB so that you can release this board from the upper metal tab. Fold it away to the right and slide apart the ribbon cable from this board and place aside.
    • Lift the LCD display away from the camera and again carefully remove two ribbon cables and place aside.
  5. Sony DSC-HX50V Lens Replacement: passo 5, immagine 1 di 1
    • Remove the three screws. Gently use a spudger to lever/remove the metal assembly away from the camera body and place it aside.
  6. Sony DSC-HX50V Lens Replacement: passo 6, immagine 1 di 1
    • Gently unplug the three ribbon cables.
    • Do not attempt to completely remove the ribbon cables as they are attached to other parts.
  7. Sony DSC-HX50V Lens Replacement: passo 7, immagine 1 di 3 Sony DSC-HX50V Lens Replacement: passo 7, immagine 2 di 3 Sony DSC-HX50V Lens Replacement: passo 7, immagine 3 di 3
    • Gently push the two ribbon cables out of the way.
    • Now you can gently push the lens assembly from the front of the camera to clear it from the body, to be completely removed.
  8. Sony DSC-HX50V Lens Replacement: passo 8, immagine 1 di 3 Sony DSC-HX50V Lens Replacement: passo 8, immagine 2 di 3 Sony DSC-HX50V Lens Replacement: passo 8, immagine 3 di 3
    • The lens assembly is now removed from the body.
Conclusione
Altre 7 persone hanno completato questa guida.
Un commento
Thank You!
Could not have done it without this guide.
Robert Mirski - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 36
Tutti i Tempi: 6,005
