Salta al contenuto principale
Sony Clie PEG-T615C Thumb Dial Replacement
Cosa ti serve
  1. Sony Clie PEG-T615C Thumb Dial Replacement, Thumb Dial: passo 1, immagine 1 di 1
    • First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
  2. Sony Clie PEG-T615C Thumb Dial Replacement: passo 2, immagine 1 di 1
    • Remove the screw directly above the thumb dial panel.
  3. Sony Clie PEG-T615C Thumb Dial Replacement: passo 3, immagine 1 di 1
    • Remove the screw from thumb dial panel on the right handed side of the device.
  4. Sony Clie PEG-T615C Thumb Dial Replacement: passo 4, immagine 1 di 1
    • Remove screw from lower right side of the device.
  5. Sony Clie PEG-T615C Thumb Dial Replacement: passo 5, immagine 1 di 1
    • Remove 1 screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Thumb Dial Replacement: passo 6, immagine 1 di 1
    • On the bottom of the device, remove both the left and right screws.
  7. Sony Clie PEG-T615C Thumb Dial Replacement: passo 7, immagine 1 di 1
    • Remove the thumb dial panel by sliding it away from the device.
  8. Sony Clie PEG-T615C Thumb Dial Replacement: passo 8, immagine 1 di 1
    • Remove the back panel exposing the inside of the device.
  9. Sony Clie PEG-T615C Thumb Dial Replacement: passo 9, immagine 1 di 1
    • Locate thumb dial on top right side of the board.
  10. Sony Clie PEG-T615C Thumb Dial Replacement: passo 10, immagine 1 di 1
    • Follow ribbon wire to locate where it plugs into the board. The plug is a flat black square.
  11. Sony Clie PEG-T615C Thumb Dial Replacement: passo 11, immagine 1 di 1
    • Pull plug straight up to remove from board.
Conclusione
Rob
Membro da: 10/04/11
1 Reputazione
2 Guide realizzate
UW Stout, Team 5-6, Zhou Fall 2011 Membro di UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,071
