Salta al contenuto principale
Sony Clie PEG-T615C Battery Replacement
Cosa ti serve
  1. Sony Clie PEG-T615C Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove two screws from the thumb dial panel on the back of the device.
  2. Sony Clie PEG-T615C Battery Replacement: passo 2, immagine 1 di 1
    • Remove one screw from the upper right corner on the back of the device.
  3. Sony Clie PEG-T615C Battery Replacement: passo 3, immagine 1 di 1
    • Remove one screw from the thumb dial panel on the right side of the device.
  4. Sony Clie PEG-T615C Battery Replacement: passo 4, immagine 1 di 1
    • Remove one screw from lower right side of the device.
  5. Sony Clie PEG-T615C Battery Replacement: passo 5, immagine 1 di 1
    • Remove one screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Battery Replacement: passo 6, immagine 1 di 1
    • Remove two screws from the bottom of the device.
  7. Sony Clie PEG-T615C Battery Replacement: passo 7, immagine 1 di 1
    • Remove the thumb dial panel by sliding it away from the device.
    • You can do this step earlier, after you remove all of the screws from the thumb drive panel.
  8. Sony Clie PEG-T615C Battery Replacement: passo 8, immagine 1 di 1
    • Remove the back panel, exposing the inside of the device.
  9. Sony Clie PEG-T615C Battery Replacement: passo 9, immagine 1 di 1
    • Remove one screw located on the board below the battery.
  10. Sony Clie PEG-T615C Battery Replacement: passo 10, immagine 1 di 1
    • Unplug the male battery plug on the battery wire from the female battery plug on the board.
  11. Sony Clie PEG-T615C Battery Replacement: passo 11, immagine 1 di 1
    • Remove the battery by sliding it out of the side of the device.
Conclusione
Rob
Membro da: 10/04/11
1 Reputazione
2 Guide realizzate
UW Stout, Team 5-6, Zhou Fall 2011 Membro di UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,268
