Salta al contenuto principale
Sony Clie PEG-SL10 Motherboard Replacement
Cosa ti serve
  1. Sony Clie PEG-SL10 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove the six screws holding the case together.
  2. Sony Clie PEG-SL10 Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the seven screws holding the motherboard to the device.
  3. Sony Clie PEG-SL10 Motherboard Replacement: passo 3, immagine 1 di 1
    • Unclip the battery harness power cable from the motherboard.
  4. Sony Clie PEG-SL10 Motherboard Replacement: passo 4, immagine 1 di 1
    • Unclip the scroll wheel power cable from the motherboard.
  5. Sony Clie PEG-SL10 Motherboard Replacement: passo 5, immagine 1 di 1
    • Pull the left clip to remove the cable.
  6. Sony Clie PEG-SL10 Motherboard Replacement: passo 6, immagine 1 di 1
    • Pull out the two clips from the center to remove the power cable.
  7. Sony Clie PEG-SL10 Motherboard Replacement: passo 7, immagine 1 di 1
    • Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
  8. Sony Clie PEG-SL10 Motherboard Replacement: passo 8, immagine 1 di 1
    • Extend both sides of the left clip to remove the power cable.
  9. Sony Clie PEG-SL10 Motherboard Replacement: passo 9, immagine 1 di 1
    • Pull out the center clip to remove the power cable.
  10. Sony Clie PEG-SL10 Motherboard Replacement: passo 10, immagine 1 di 1
    • Pull the right clip out to remove the right cable.
  11. Sony Clie PEG-SL10 Motherboard Replacement: passo 11, immagine 1 di 1
    • The motherboard is removed. To install the new motherboard, follow the directions in reverse.
Conclusione
Emily
Membro da: 10/18/11
3 Reputazione
3 Guide realizzate
James Madison, Team 1-4, Allen Fall 2011 Membro di James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
3 Membri
4 Guide realizzate
Un commento
I have a full reset whenever I take the battery out to recharge it. Given that all replacement motherboards will be as old as the unit, is there anyway to fix the board (I presume it’s a capacitor or super cell that keeps the charge long enough to swap the battery over normally?). The three cells seem to be soldered onto the board, but I presume could be replaced?
Anyone know of a way to fix this?
Benjamin S. Leveritt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,331
