Salta al contenuto principale
Skirt Lining Replacement
Cosa ti serve
  1. Skirt Lining Replacement, Lining: passo 1, immagine 1 di 2 Skirt Lining Replacement, Lining: passo 1, immagine 2 di 2
    • Cut out the old or damaged skirt lining. This can be done using a pair of scissors, or a razor blade/seam ripper if you have one.
    • Blades might give you a neater finish after this step but take longer to use.
    • Be careful when using sharp objects.
  2. Skirt Lining Replacement: passo 2, immagine 1 di 2 Skirt Lining Replacement: passo 2, immagine 2 di 2
    • After threading the needle, take some new lining (chiffon or silk material), iron it out, and make sure the lining isn't longer than the actual skirt.
  3. Skirt Lining Replacement: passo 3, immagine 1 di 3 Skirt Lining Replacement: passo 3, immagine 2 di 3 Skirt Lining Replacement: passo 3, immagine 3 di 3
    • Gently insert the threaded needle. Be careful not to prick your finger.
    • Push through the skirt fabric from below.
    • Pull the needle all the way out to form a stitch.
  4. Skirt Lining Replacement: passo 4, immagine 1 di 1
    • Continue with step 3 until you create stitches around the whole waistband of your skirt.
    • It should look somewhat like this when you make it halfway around the waistband of the skirt.
  5. Skirt Lining Replacement: passo 5, immagine 1 di 1
    • Cut out extra fabric if you have any, and here's what the waistline of your skirt should look like.
    • Try it on!
Linea Traguardo
Rena
Membro da: 01/11/24
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 24
Tutti i Tempi: 65
