Salta al contenuto principale
Samsung Galaxy TabPro S Screen Replacement
Cosa ti serve
  1. Samsung Galaxy TabPro S Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Apply heat around the screen to loosen the glue holding in the screen. A heat gun would be preferable as it needs to get relatively warm.
  2. Samsung Galaxy TabPro S Screen Replacement: passo 2, immagine 1 di 1
    • Attach the small suction cup near the edge of the screen.
    • Pry in between the screen and the frame with a plastic spudger.
    • Pull up with the suction cup while prying and the screen should begin gently disconnecting.
    • Use the spudger on all edges of the tablet between the screen and the frame.
    • The screen should release.
  3. Samsung Galaxy TabPro S Screen Replacement: passo 3, immagine 1 di 1
    • Disconnect the thick cable from the motherboard
    • Disconnect the golden cable from the motherboard
Conclusione
IUPUI, Team 3-4, Harley Spring 2022 Membro di IUPUI, Team 3-4, Harley Spring 2022
IUPUI-HARLEY-S22S3G4
3 Membri
3 Guide realizzate
Un commento
Where to find a replacement screen for a 2017 Samsung tab S pro 12 inch ?!?!?
ori gosi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 33
Tutti i Tempi: 796
