Salta al contenuto principale
Samsung Galaxy TabPro S Front-Facing Camera Replacement
Cosa ti serve
  1. Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: passo 1, immagine 1 di 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: passo 1, immagine 2 di 2
    • Remove the back of the tablet by prying the plastic back using a flat tool.
    • When the tool has been inserted under the back, slide it all the way around the tablet to fully unclip it.
  2. Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 2, immagine 1 di 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Once the back has been removed, disconnect all cables using a pair of tweezers to avoid damaging any components.
    • Once the cables have been disconnected, remove the battery using a flat plastic tool (not the metal spudger).
  3. Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the screws that secure the motherboard.
    • Remove the metal plate once the screws are gone and the motherboard will be ready to be replaced.
  4. Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 4, immagine 1 di 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 4, immagine 2 di 2
    • Remove motherboard by prying it up with a flat plastic opening tool (not metal spudger).
    • Be sure that all components have been disconnected beforehand, especially the front-facing camera (located above the motherboard in the top center of the frame).
  5. Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 5, immagine 1 di 2 Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 5, immagine 2 di 2
    • Once the camera has been disconnected from the motherboard, it can be removed using a pair of pliers.
Conclusione
IUPUI, Team 3-4, Harley Spring 2022 Membro di IUPUI, Team 3-4, Harley Spring 2022
IUPUI-HARLEY-S22S3G4
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 269
