Salta al contenuto principale
SHARP EL-546XT Battery Replacement
Cosa ti serve
  1. SHARP EL-546XT Battery Replacement, Battery: passo 1, immagine 1 di 2 SHARP EL-546XT Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Place the calculator on a clean workspace with the back facing up.
  2. SHARP EL-546XT Battery Replacement: passo 2, immagine 1 di 3 SHARP EL-546XT Battery Replacement: passo 2, immagine 2 di 3 SHARP EL-546XT Battery Replacement: passo 2, immagine 3 di 3
    • Remove the calculator cover if you had it on.
    • Turn off the calculator using the 2nd F button then clicking the ON button.
  3. SHARP EL-546XT Battery Replacement: passo 3, immagine 1 di 3 SHARP EL-546XT Battery Replacement: passo 3, immagine 2 di 3 SHARP EL-546XT Battery Replacement: passo 3, immagine 3 di 3
    • Put the calculator cover back on to ensure you don't accidentally press any buttons.
    • Remove the screws from the battery door.
    • Do not remove the other screws as they are not for the battery compartment.
  4. SHARP EL-546XT Battery Replacement: passo 4, immagine 1 di 2 SHARP EL-546XT Battery Replacement: passo 4, immagine 2 di 2
    • Remove the battery door from the calculator.
  5. SHARP EL-546XT Battery Replacement: passo 5, immagine 1 di 3 SHARP EL-546XT Battery Replacement: passo 5, immagine 2 di 3 SHARP EL-546XT Battery Replacement: passo 5, immagine 3 di 3
    • Use a spudger to gently push the coin battery out through the small hole located below the battery.
    • Be careful not to apply too much force when pushing the old battery out to avoid damaging the calculator or the battery compartment.
  6. SHARP EL-546XT Battery Replacement: passo 6, immagine 1 di 3 SHARP EL-546XT Battery Replacement: passo 6, immagine 2 di 3 SHARP EL-546XT Battery Replacement: passo 6, immagine 3 di 3
    • Gently insert the new battery into the battery compartment.
    • Handle the new batteries with care.
  7. SHARP EL-546XT Battery Replacement: passo 7, immagine 1 di 2 SHARP EL-546XT Battery Replacement: passo 7, immagine 2 di 2
    • Ensure the battery is properly slotted in the battery compartment.
    • Close the battery compartment with the battery door.
  8. SHARP EL-546XT Battery Replacement: passo 8, immagine 1 di 3 SHARP EL-546XT Battery Replacement: passo 8, immagine 2 di 3 SHARP EL-546XT Battery Replacement: passo 8, immagine 3 di 3
    • Attach the screws back to the battery door.
  9. SHARP EL-546XT Battery Replacement: passo 9, immagine 1 di 3 SHARP EL-546XT Battery Replacement: passo 9, immagine 2 di 3 SHARP EL-546XT Battery Replacement: passo 9, immagine 3 di 3
    • Take the calculator out of the cover.
    • Turn on the calculator and test if it's functioning.
Linea Traguardo
Mithunan Sivagnanam
Membro da: 05/22/23
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 31
Tutti i Tempi: 494
