Salta al contenuto principale
Ring Elite Doorbell Button Replacement
Cosa ti serve
  1. Ring Elite Doorbell Button Replacement, Situation: passo 1, immagine 1 di 2 Ring Elite Doorbell Button Replacement, Situation: passo 1, immagine 2 di 2
  2. Ring Elite Doorbell Button Replacement, Cut old button away: passo 2, immagine 1 di 3 Ring Elite Doorbell Button Replacement, Cut old button away: passo 2, immagine 2 di 3 Ring Elite Doorbell Button Replacement, Cut old button away: passo 2, immagine 3 di 3
    • The button is very difficult to replace by disassembly. The seller recommends to pull out the button slightly with your fingers and slide a screwdriver around the seam. I found this didnt work for me
    • The old button is clipped around the housing with three clips. Cutting the centre of the button out allows easier access to the clips from the inside
    • Be careful with the cutters to not go too deep and damage the inner circuitry of the button, try to cut parallel to the front of the button
    • The green ring represents the remains of the old button and the red ring represents the button housing which the button is clipped to
  3. Ring Elite Doorbell Button Replacement, Remove the button remains: passo 3, immagine 1 di 2 Ring Elite Doorbell Button Replacement, Remove the button remains: passo 3, immagine 2 di 2
    • Carefully insert the pointed end of a metal spudger into the gap between the button and the button housing and rotate to seperate the clips from the housing
    • Then pull back on the button remains as you unclip the clips
    • The clips are located at 12 oclock , 4 oclock and 8 oclock
  4. Ring Elite Doorbell Button Replacement, Insert the new button: passo 4, immagine 1 di 3 Ring Elite Doorbell Button Replacement, Insert the new button: passo 4, immagine 2 di 3 Ring Elite Doorbell Button Replacement, Insert the new button: passo 4, immagine 3 di 3
    • Insert the new button with the notch at 6 oclock. It should line up with a tab inside the button ring
    • Push the button in firmly once lined up. It should not take too much force.
    • Done!
Linea Traguardo
Altre 4 persone hanno completato questa guida.
3 Commenti
Thanks! I found numerous YouTube guides on how to disassemble the whole unit, but will definitely try this method first. If it doesn't work I can always still go the disassembly route as a backup approach.
Tim Reczek - Replica
Supergemakkelijk zelf te doen als je ietswat handig bent. Je hebt enkel een dunne punt tang en klein schroevendraaiertje nodig. Duurde welgeteld 2 min. TOP!
Didier Delaruye - Replica
I thought the disassembly option was going to be the only way .
But used this method and it took me 2 mins to replace.
So it's a big yes from me
geoff ingram - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 63
Ultimi 30 Giorni: 288
Tutti i Tempi: 10,125
