Salta al contenuto principale
Rimuovere un bullone spanato con testa a brugola
Cosa ti serve
  1. Rimuovere un bullone spanato con testa a brugola, Rimuovere un bullone spanato con testa a brugola: passo 1, immagine 1 di 1
    • Fai un taglio sulla testa della vite.
    • Posiziona un giraviti nella fessura creata e dai dei colpetti col martello in senso antiorario in modo da allentare la vite.
    • Finisci di svitare col giraviti.
Linea Traguardo
Altre 44 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Andrea Vitali ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Wolfgang
Membro da: 02/17/12
597 Reputazione
2 Guide realizzate
6 Commenti
Use the same technique for Philips or crosshead screws.
Use a grinding / cutting disk, not a saw blade. Apply the rotating cutting disk gently, do not force or it will break.
If this is a toughened steel or stainless steel bolt (much tougher), it will be best to use a reinforced cutting disk.
Use a dusk mask to avoid breathing the dusk from the disk !
(No, I don't usually, but I should !)
Frank B - Replica
While this works it is very difficult to not ruin the material around the bolt.
What I do is use a torx bit. size one up that is slightly larger then the hole and then firmly tap it in. atttach your drive handle a turn slowly while pushing down. this will normally break it free.
Also before your get to this point try putting your allen key in the hole and smack it with a hammer. sometimes the force of the hit will cause the metal to "break" enough that the allen screw wont strip.
Jamie Mcguire -
There are also specifically designed screw extractors made for this. These tools are generally two-sided: one side is used to drill the hole, while the other is inserted to extract. If the process works, the surrounding area is undamaged.
Karl Kaufmann - Replica
Use another Allen bolt to weld over it and then you can easily remove the Allen bolt with the help of Allen key
Tushar Pednekar - Replica
And if for any reason if you can't weld then just drill the head of the Allen bolt so it's shears off. And then u can easily remove the rest
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 95
Ultimi 30 Giorni: 435
Tutti i Tempi: 258,913
